Roaming in France
Ismail2013
Hi. I have free roaming on my contract and it’s not working. I am in france and I need to use my phone. Any help?
Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks. You've posted in the PAYG section but referred to a pay-monthly contract. The two are different - which do you have?
There is no free roaming on PAYG. On PAYG there are charges for using your pack allowances in the EU of either £2.50 / day or £10 / week.
Had you used that PAYG SIM for making calls or texts in UK before going abroad? To be used abroad EE PAYG SIMs need 1st activating on EE's home UK network. If it wasn't you can't now use it until you return to UK.
