04-02-2024 04:06 PM
Hello, I got the same message on Monday, January 29, 2024:
"Hi, it seems quite a while since you last made a call, sent a text or used data. It's important that you use your phone otherwise you may lose your number as per our terms and conditions".
However, I sent a message earlier on January 9, 2024, and I don't have any packs or add-ons in my account. I also checked my credit balance before and after sending the message, which I found was chargeable. So I am not sure as well if this message is a gentle reminder or if I have to do another chargeable activity to keep my EE account working?
Thanks!
05-02-2024 07:56 AM
05-02-2024 11:43 AM
Hi Chris!
The message I sent before the one on January 9th was on November 6.
Rita
05-02-2024 12:23 PM
OK, thanks @RITA_N
It could be that the message was queued before you made that text on 9th January. If you receive any more messages like this, I recommend speaking with our Mobile Care team, just to check.
05-02-2024 12:30 PM
Okay , thanks Chris!
Regards,
Rita
