07-02-2022 10:16 AM
Hi.
I currently reside in the EU and keep my pay as you go ee number so that my parents can call me whenever (elderly and not tech savvy). I recently cannot make outgoing calls or send SMS but incoming calls and SMS are working.
Will I be able to keep the number active if I'm topping up frequently?
Appreciate your help!
07-02-2022 11:17 AM
Hi there @LisaCS
When was the last time you made a chargeable activity as below?
Calls, texts and data usage made using your allowance from your pack do not count towards a chargeable activity.
Thanks 🙂
07-02-2022 11:24 AM
Hi Leanne.
I topped up last week, but haven't been able to make calls or send SMS (presumably because of the changes to EU roaming?)
Thanks for your help.
07-02-2022 11:36 AM - edited 07-02-2022 11:42 AM
@LisaCS : Changes to EU roaming haven't come in yet & so cannot affect the validity of your PAYG SIM.
Before last week's top-up when did you last use it for a chargeable action as per @Leanne_T 's post? EE PAYG SIMs are deactivated after 6 months of non-use. It may have already gone into hibernation before you topped-up.
07-02-2022 12:16 PM
Hi @XRaySpeX
I last topped up 8th October 2021 and used it to make a brief call in Oct. It's not let me send SMS since this point either.. before this I topped up in July and April also.
It's still allowing incoming calls and SMS...would this be the case if the number has gone into hibernation?? How can this issue be rectified?
07-02-2022 12:22 PM
Hi @LisaCS
Thanks for coming back to us.
Please give our Pay as you go Care team a call on +44 7953966250, and the team will get this looked into for you.
Leanne 🙂
07-02-2022 12:25 PM
As you are still able to receive calls I would think that it hasn't gone into hibernation. Not so sure that receiving texts would come to the same conclusion. Also you say you made a chargeable (?) call only 4 months ago.
For sending texts, check your phone's Messaging app has the Message Centre no. setting for EE as +447958879879.
07-02-2022 12:34 PM
@XRaySpeX yes I made a chargeable call in Oct. I just updated the number in the message app settings as per your advice and still msgs are not sending.
07-02-2022 12:39 PM
Hi @Leanne_T
Thanks for your reply. I can't make calls, the app I use for international calls doesn't work with the number as it's not connecting when I select the relevant option via the keypad, and financially I can't call from my foreign number.
Is there a call back service available or live chat perhaps?
07-02-2022 01:05 PM
