Please help me
Christian2121
Please I can’t register my sim there is no network on my phone after I travelled to Nigeria
On pay-monthly, this needs to be enabled manually - usually by texting ROAMING to 150 before leaving the UK.
If you are on PAYG and now find yourself abroad without having enabled roaming, the only recourse is to use that SIM on EE's UK network first. There is no workaround.
Had you used that PAYG SIM for making calls or texts in UK before you left to go abroad? To be used abroad EE PAYG SIMs need 1st activating on EE's home UK network. If it wasn't you can't now use it until you return to UK.
