Pay as you go help please
Seanyorky
My son has a pay as you go SIM and hardly uses the phone I have gotten him a new SIM which doesn't require constant topping up. I have tried to ring 150 to get a PAC code and it says phone disconnected. I tried also text 150will not send and also the PAC message to the alternative number with no success. Is their any way to keep his old number any of you kind people know.
Regards
Sean
Katie_J
Hello @Seanyorky.
Welcome to the EE Community.
When was the last time the SIM was used for any chargeable activity?
Have you tried calling 0800 956 6000?
Katie
Hi Katie it's been well over 6months possibly longer. I will try the number thank you and see if that helps I will keep the thread updated when I get to call the number. Busy at work at the mo 👍
Your PAYG SIM has gone into hibernation after such a long period of non-use.
EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then have a further 3 months period of grace to call EE to reactivate it before it is lost completely.
