Not received SMS
adrianrankiewic
I have a problem with the EE network. After arriving in Poland, I'm not receiving SMS messages from Polish numbers. When I send an SMS from my EE SIM card to a Polish number, it also doesn't go through. However, when I send an SMS to the UK, it works fine, and I received a message sent from the UK as well. Roaming is enabled, and I have £8 credit on my account. What could be the issue? The network I'm automatically connected to is Orange
7 REPLIES 7
Debbie_G
Hey @adrianrankiewic
Have you tried to text more than one Polish number?
Can you call the number from your phone?
Do you have the number saved as a contact?
Debbie 🙂
I can make calls from an English number to Polish numbers; I tried a few and it works fine. The only problem is with SMS messages sent from Polish numbers to my English number.
Katie_B
Hello @adrianrankiewic
Thanks for getting back to us.
Have you tried manually connecting to another available network?
Speak soon,
Katie
Yes, it did not change anything, I also put the card into another phone, but it didn't help
Katie_B
Hi @adrianrankiewic
Thanks for trying.
Are the texts coming from more than one number?
Katie
I am not receiving any SMS messages from the bank needed to authorize transactions, nor from other numbers
Katie_B
I'd recommend reporting this to our technical care team @adrianrankiewic
They will be able to look into this further.
Katie
