Network problem
Ana91
Hi, I have a problem with my number phone. I am in Poland now but my friends from Uk can't call me, my number does not match. Please help
Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
12 REPLIES 12
What do you mean by your number not matching?
@Ana91 : Can you make calls & texts?
I had this situation few months ago, I chatted with ee support team on Facebook and she said
'If you don't use the SIM card for 45 days or more for outgoing text/call or top up, the SIM card gets expired.'
so I’m afraid this situation happened again… I need keep my number but I’m not in UK and I can’t go to EE shop etc
She helped me then, I topped up my account and got my number back. Now I can't connect to FB and talk online
@Ana91 wrote:
she said 'If you don't use the SIM card for 45 days or more for outgoing text/call or top up, the SIM card gets expired.'
The truth is for 179 days !
i know it's my fault but i really need to get my number back ☹️ could you help me? Please
EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then have a further 3 months period of grace to call EE to reactivate it before it is lost completely.
do you know how to contact them? my number is not active…
Christopher_G
Hi @Ana91
Welcome to the community.
You can find our contact numbers, including a number to call from another phone, here on our contact us page.
Our customer service team will be able to look into whether the number can be reactivated or not.
