Help this is making me lose my mind
Dragonface221
My phone recently started to play up and will not let me recive calls or messages, I don't know if this is to do with the phone or the sim card, I tried to top up to see if that's the issue but I won't even let me send a message also whenever someone tries to call me it says my number is wrong even when it's not so I currently don't know what to short of getting a new sim but then I'll need to change my number. Help please
Sounds like your PAYG SIM has gone into hibernation.
When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
Thank you, I ended up getting a new sim, in the end the phone number was cut of dur to the issue u said and now I know I need to keep buying credit yo keep it active
