10-11-2025 06:57 PM
12-08-2026 01:02 PM - edited 12-08-2026 01:03 PM
@Rabbi-Eddie : Sounds like your PAYG SIM may have gone into hibernation due to non-use & then been completely deactivated. If it has, topping-up now would be too late.
When did you previously make a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then have a further 3 months period of grace to call EE to reactivate it before it is lost completely.
You needed to make a chargeable action like making a chargeable call or text, topping up or buying a Pack or Add-on, not just using your mins, texts or data from your pack.
10-11-2025 07:15 PM
Hi @Rabbi-Eddie
Are you in the UK.
Have you tried restarting your device.
10-11-2025 07:31 PM
@Rabbi-Eddie : Are texts to 150 going OK? If so, What does texting AL to 150 from your no. fully report verbatim (it is free)?
When did you previously make a chargeable action? Was that the text in Oct. this year?
10-11-2025 07:52 PM
12-08-2026 11:42 AM - last edited on 12-08-2026 12:13 PM by Leanne_T
Can't even send "Balance" nor "Roaming" nor "Help" to 150 from my E E pay as you go....
I have rather had to call customer services on 07953 966 150 using another network!
This is NOT on! I feel inadequate
Eddie
[mod edit: personal details removed from the public forum]
