17-11-2023 03:53 PM
I changed from the bill phone I had for about 25 years to a pay as you go as I was leaving the UK but I still need to use the phone now and again for bank stuff as it's the registered number. But I can't make any calls from it or send sms to get this roaming add on. I can't believe it's such a faff. There is more than enough credit on the phone to just ring direct to the bank and do what I need to do and if credit ran out then I'd top-up. Any tips? I tried calling and get a 'these calls are blocked' when I sms 'roameu1d' to 150 (from outside the UK) that is blocked too, so what am I missing?
17-11-2023 05:15 PM
It's a bit ridiculous really, how hard can it be to turn on calls and test or why would they even need to be turned on. It's a bog standard PAYG account so it should be possible to make a call, pay £x for 5 min or whatever. I don't get why this roaming add on is such a trauma - 4 hours trying to sort it now and nothing, just passed around call agents.
17-11-2023 05:32 PM - edited 17-11-2023 05:33 PM
It's not calls or texts that need enabling, it's access to foreign networks. Your phone needs either a mobile network connection or (if in the UK) a WiFi-connection, in order to use functions that rely on a mobile network. If you have neither, you cannot make or receive calls, send or receive text messages, or use mobile data. Exactly the same as if you're in an area with no network coverage.
When you travel abroad, you are not using EE's network but the local networks in those countries. Your SIM therefore needs permission to connect to those foreign networks, which is called roaming. Without those permissions, your phone has no coverage - with the consequences on calls, texts & mobile data. In an earlier reply, you mention you are able to use WhatsApp - this uses the internet, are you definitely connected to a mobile network when doing so? Or using WiFi?
EE's process is that PAYG SIMs are auto-enabled with first use in the UK. Billing add-ons merely reduce the cost of the usage.
17-11-2023 05:32 PM
It won't until you return to UK as you never used that PAYG SIM in the UK.
17-11-2023 05:36 PM
17-11-2023 06:11 PM
@Des72 wrote:
My phone is connected to KPN wifi in The Netherlands
Roaming is auto-enabled on PAYG once the SIM is used in the UK first.
No roaming facility means no mobile network coverage abroad. No network coverage abroad has the same impact on your phone's functionality as no mobile coverage anywhere else. You can't make or receive calls without a network.
You can enable roaming data on your phone, but without the SIM having roaming permissions that is futile.
What do you mean by the "daily access SMS message"?
17-11-2023 06:19 PM
17-11-2023 06:29 PM
@Des72 wrote:
I shouldn't need an add on for anything, the sim works
If the SIM was working, you would have mobile network coverage. The add-on is completely irrelevant for this purpose.
Your phone will show a mobile network connection if roaming is enabled. Calls would naturally follow.
