doro 8100 not allowing answer call
Kate203
Hello am 80 =year old, using doro 8100, when I receive a call i see the box that says decline or answer , I click answer and message disappears but phone call keeps ringing, I have also difficulty in getting phone to slide up. and also tried using a stylus....Any advice appreciated. as I keep losing calls and have to ring them back.
Kim
Kate203
Thanks Alex, yep done all that.......BUTTTTT  yay! managed to answer TWO calls today, so maybe something  has changed.
Appreciate all comments always good to liase with someone. Thank you, will let you know if I revert back to not being able to answer.
9 REPLIES 9
@Kate203  Do you have issues when just pressing the screen ?  Can you press the icons ok and access them without issue?
Kate203
Hello Chris thank you for replying. I  have no problems accessing the icons on the screen and can swipe up when logging in .It is just when I receive a call doh!
Lesley_W
Hi @Kate203
Thanks for coming to our community.
Have you only recently gotten the phone? Or have you had it a while and this problem has just started happening?
Lesley
Hello Lesley
Had phone about 12 months, and noticed this about 6 months ago,Doro support suggested using Stylus, which does not solve problem. Strange that it is only happening when trying to answer a call. As I say I can press the answer and (decline/answer) disappear, but phone continues to ring instead of letting me speak with caller.So then when they hang up I have to ring them back. doh!!
Lesley_W
Thanks @Kate203
Does it happen with all calls?
Lesley
Kate203
Yes every call doh!!
Alex_H
@Kate203 You have probably already done so, but just wanted to check as it had not been mentioned, has the phone been restarted since the issue began?
Are there any available software updates in Settings> About phone> System/Software updates>Download and install?
Alex
Kate203
Alex_H
@Kate203 Glad to hear it has worked today, thanks for letting us know. Fingers crossed it stays working 🙂
Alex
