Smart watch add on
Harry66
Hi I have a smart watch that I brought from Currys out right I'm just wondering can I add a smart watch plan to the watch or do I have to buy the smart watch from EE themselves.
@Harry66  If you get a cellular watch you can add a tariff to it via the wear app.  You have to be a contract customer ( including sim only contract ) to add a watch tariff.  The watch tariff will be £7 per month on a rolling 30 day contract and you’ll get 10Gb of data for the watch, it’ll share your call and text allowance from your contact.
6 REPLIES 6
danny19970
Skilled Contributor
Skilled Contributor
If you ee allows you to add a line on your account you should be able to you can do this on the wach app what watch do you have
I have a Samsung galaxy watch 4 with WiFi only but I'm thinking of buying one with cellular built-in just wondering if I can then a the watch plan from ee on to it.
Is that a yes or no just need 100% honesty
Sent from Outlook for Android<>
I have the Samsung galaxy watch 4 4g just want to know if I can add a mobile data to the watch if I go to EE people are saying yes then they are saying no I'm just so confused on weather you actually can or not just need a yes or no answer.
Katie_J
Hello @Harry66
If your account is eligible you will be able to add the £7 data plan within the wear app.
Katie
