My IMEI isn't recognised
teddi97
Hello,
I have bought a new SIM, and tried to use IMEI through but it isn't recognised for some reason.
Please see the screenshot below.
16 REPLIES 16
Eddy2760
Expert Contributor
Expert Contributor
Is the mobile you purchased from Korea unlocked to all networks? Have you used any other uk sim in that unit?
Eddy
@Eddy2760  if you used a three Sim card in it, then the device isn’t locked. What are you trying to do.
Eddy2760
Expert Contributor
Expert Contributor
@teddi97 ^^ not me lol 😂 I asked them a question lol 😂
Eddy
I have been using only Three network since I have moved in UK, and I did
not unlock the content on it because I did not need it but I do need it now.
Eddy2760
Expert Contributor
Expert Contributor
if you have been using uk sim then there shouldn’t be a need to get the unit unlocked, there maybe a issue with the SIM card.
do you have a EE store close to you ? If so call into store and the friendly staff will be more than happy to take a look for you 👌
Eddy
Alright, I'll just go to the shop to ask. Thank you
Eddy2760
Expert Contributor
Expert Contributor
Your welcome 🙏
Eddy
