How to Unlock Huawei Router B525s-23a
Gotard
I bought this Wi-Fi router but it has got sim lock
ee says can unlock all devices from them for free
can you unlock mine please?
20 REPLIES 20
You can just apply for unlocking by using the Unlocking your device form and giving its IMEI no.
That doesn’t work. I did try
keep saying something went wrong and to try later. I tried many times and nothing.
Did you obtain the IMEI from the router's System Settings?
It’s on the router sticker and on the box
If I use some online IMEI check system it does recognise the imei and name of the router.
when I put on EE website is says there is a problem. So I’m confused
But is it the same in its actual settings? It would be a sanity check to be sure. IMEIs come in ranges for a particular device model & so would be recognised even if it were wrong.
I don’t know how to get to the settings.
could you advise please?
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then look for its System Settings.
Hi
I did open setting on my laptop and it’s the same IMEI number
what would you advice next ?
Sorry, impasse. All you can do is call CS to unlock it.
