on 09-01-2025 04:01 PM
I have an old Nokia that is locked to orange but when I input the imei code into the ee unlock code website, I get an error saying "Application error: a client-side exception has occurred" What do I do?
Solved! Go to Solution.
on 09-01-2025 06:35 PM
Hi there @pugman227227
If you call our mobile guides on 0800 956 6000, they will check the IMEI number and see if they can help get the device unlocked for you.
Leanne 🙂
on 09-01-2025 05:16 PM
It is unlikely an old device such an old orange device can be unlocked by EE especially if it runs windows or older firmware.
Try a third party provider or search google to establish if you can unlock it yourself.
Leanne 🙂
