Can anyone help .please. the Pattern to open my phone is saying wrong pattern
Sue249
My phone won’t open it says my pattern input is wrong and has blocked me tried re tried chatbot no help at all .
any one any ideas .? T.i.a.
FYI you have a short time after posting to edit, negating the need to post multiple short replies.
Apple guide to unlocking phones - https://support.apple.com/en-gb/118430?iphone-authentication-type=iphone-with-face-id
Android guide to unlocking phones - https://support.google.com/android/thread/200166141/why-my-android-is-not-accepting-pattern-lock-eve...
6 REPLIES 6
Schockwave
Hello @Sue249 ,
Welcome to the community,
No, but the only thing I can suggest is doing a factory reset, just hope that you have a back up so that you can reinstall everything from your back up, once you have done the factory reset.
Northerner
Hi @Sue249
You normally have a second password/pin option if you forget the pattern.
If not then as @Schockwave says.
You're effectively asking "how do I bypass my PIN/pattern protection"? - the security that is specifically intended to secure a phone until the correct details are inserted.
EE are a network operator and can't directly assist you besides pointing you towards Android/Apple's help pages. Which do you have?
Yes I have apple and android .thanks for your reply .
S W
[Mod edit: name redacted. Please do not post personal details on public boards.]
I’ve always used finger print and pin .its not giving me the option to use them .thanks for your reply 🙂
S W
