25-07-2026
02:54 PM
- last edited on
25-07-2026
05:02 PM
hanish_reddy
Witam, jak aktywować drugą kartę, którą posiadam w planie, ten numerów nie działa, powinien działać 739***?
[MOD EDIT: removed personal details.]
26-07-2026 09:06 AM
Hi @Koneczny,
Welcome to the EE Community
Is this a Payg SIM you recently bought in a shop or via our website? Does the SIM show any connection when in the phone? If you ordered via our website and selected a SIM without top up, have you topped up since receiving it?
You may be best off calling our team as they will be able to check the number is active and ready to use.
Alex
25-07-2026 02:59 PM
Hi @Koneczny
Are you in the UK.
Is this a PAYG SIM.
25-07-2026 03:46 PM
Yes, I'm in the UK and this is a sim card
25-07-2026 04:40 PM
@Koneczny wrote:Hi, how do I activate the second SIM I have in the plan? This number doesn't work, should 7398****** work?
26-07-2026 09:06 AM
Hi @Koneczny,
Alex
