iPhone 14 pro max
Reece325
How can I find out what’s goin on with my upgrade said 2 weeks to get it in stop but had no text or email confirming
6 REPLIES 6
@Reece325  There is different waiting times for the pro max depending on what colour and storage size you ordered.  The times range from 7 to over 28 days.
Jon_K
Former EE Employee
Hi @Reece325.
What colour and memory size did you order?
Jon
Black and 128 gb
Jon_K
Former EE Employee
Thanks @Reece325.
That model is expected to be dispatched within 14 days.
DPD will text you when your order is ready to be delivered.
Jon
I’m just loosing my patience. The order for the purple 14pro max was placed on the 18th October . It’s been 30days today .not even an update on the tracking order.
