on 15-10-2023 06:24 PM
I have ordered iPhone 15 pro max Blue . I get the order number but date not mentioned. Kindly support when it will be delivered as I have no idea
Solved! Go to Solution.
on 16-10-2023 09:43 AM
Hi @Bibekthapa
Which memory size did you choose? I'll check our estimated delivery times for you.
Hi @Bibekthapa
on 16-10-2023 11:39 AM
Hi Christopher
iPhone 15 pro max Blue 256gb
on 16-10-2023 12:02 PM
Thanks, @Bibekthapa
The current estimate for that version is to expect dispatch within 28 days of ordering. DPD will be in touch with you when it's ready to be delivered. Thank you for your patience so far.
