on 09-09-2024 05:20 PM
Hi, when will the Pixel 9 Pro be delivered by those that have preordered? The staff member said that the release date was today (09/09/24) and it might be delivered either on the release day or the day after, is this still the case? Thanks!
on 09-09-2024 06:09 PM
@sesson26 Depends how many others in front of you ordered the same model spec as you and how many EE receive of that model spec. A pre order isn’t a guarantee of getting it on or just after launch day. It just means as soon as the model spec that you ordered is available and you’re next in the queue it’ll be dispatched to you.
on 10-09-2024 09:05 AM
thanks for the info
on 10-09-2024 09:17 AM
there will be a backlog due to high demand.
