Phones
190Kay
I ordered a phone on the 24th off Feb what date will it come by
29 REPLIES 29
I’ve done all off that still nothing to see where my order is
Ritu_D
Thanks for giving those things a try @190Kay
I would recommend giving our guides a call they'll be able to check on your order for you.
Ritu
I still haven’t had any updates and it’s been 3 days
Chris_S
Hi @190Kay
I can imagine you're keen to get your hands on your new phone.
I'd recommend following @Ritu_D's advice and giving us a call so one of our guides can give you an update on your order.
Chris S
I’ve rang them but the options they give aren’t to see what’s happening with my phone unfortunately
Chris_S
Thanks for letting me know @190Kay
Did they confirm to you that your order had been logged correctly?
Chris S
Yes I got the email
Chris_S
Brilliant @190Kay
The confirmation email is a great indicator that your order has been logged.
As my colleague Ritu mentioned, the device was in stock when you ordered it.
We had an expected dispatch time of 1-3 days for the device.
For specific information about your order, we'd need a guide to get access to your order, so I'd recommend giving us another call.
Chris S
Oh ok it’s because I ordered it on the 24th and most the time it’s between 1-2 days
Chris_S
I'm sure it's on track to be with you soon @190Kay
I'd just like to get you some peace of mind that everything is okay with your order.
Chris S
