19-05-2025 11:01 AM - edited 19-05-2025 11:06 AM
Ordered fibre - order status page doesn't work - not a very good advert for EE!
Any estimate of when this will be working again?
thanks
Solved! Go to Solution.
on 22-05-2025 03:22 PM
@gfb8846 have you put in an order for a device, is it an upgrade?
If it is for a device, then you will get notification from DPD up to the evening before delivery and another one on the day of delivery with a one hour window.
If you are having problems ordering upgrades, you can ring customer service and speak to them by choosing option 2, which should get you through to one of the guides.
Not sure why you are having problems otherwise.
If you have ordered and have not received confirmation of your order, then check your spam/junk folder.
If the page is not loading for you, please either try another browser, also clear cache , that should solve the problem.
on 22-05-2025 04:37 PM
Hi @gfb8846
Great to hear you had an update on your order. If you're not sure if the details you were given, I'd really recommend giving the team a call so they can go through the information with you so you are up to date with the progress of your request.
Please keep us updated once you have spoken to the team.
Ali
on 03-08-2025 08:41 PM
still not fixed!
