19-12-2025 11:19 AM
Ordered a orange iPhone 17 plus 128gb I think took my upfront payment but I have not had anymore info and when I try and track my order it says something went wrong.
19-12-2025 07:07 PM
Thanks, @Dean163.
I've had a check and it looks like we have plenty of stock available for this model.
If it's been more than 48 hours since placing your order, I'd definitely recommend giving our team a call, and they should be able to check things out via your XK order reference number.
I'd also recommend downloading the DPD app and registering with your address, as this should keep you up to date on any inbound parcels too.
Peter
19-12-2025 11:25 AM
Hello @Dean163 ,
Welcome to the community,
The payment should be pending until your order is dispatched, but have you checked your spam/junk folder to see if anything is there?
You will receive notification from DPD once the device has been dispatched, up to the evening before dispatched and another one on the day with a one hour window and a PIN number you give to the driver in order to receive your order.
I would advise you, if you have not already done so to download the DPD app with the same information that EE have.
19-12-2025 11:31 AM
19-12-2025 03:42 PM
Hi @Dean163
If you have had a confirmation email, it's likely we're just waiting for stock to dispatch your order.
If you can double check and let me know exactly what you ordered, I'll see what the expected timescales are.
Lesley
19-12-2025 04:47 PM
Sorry I got order wrong it is a
iPhone 17 Pro Max 512GB Cosmic Orange
19-12-2025 07:07 PM
Thanks, @Dean163.
Peter
