Missing part of ps5 order
MarieCam1987
Hello
My partner has opened the ps5 I got him and has found the screw for the base is missing .
Can I be adviced who I contact regards this missing item .
Northerner
Hi @MarieCam1987 @Jon_K
The screw is hidden in the base. Turn the base and the screw will appear in the square(first picture,).
Secondly keep the cap off the screw hole on the bottom of the console ,(assuming you're standing it up). You don't need the screw to lie it flat.
Jon_K
Former EE Employee
Hi @MarieCam1987.
I'm sorry to hear this.
I'd recommend getting in touch with our Customer Care team and making them aware of this.
They will be able to advise what can be done for you.
Jon
Northerner
Jon_K
Former EE Employee
That's fantastic advice, @Northerner.
Thanks for confirming this.
It's been a while since I set mine up and I couldn't find the box or the instruction manual.
Jon
Thankyou so much
Thankyou for your reply
