Ipods
Claird5669
Hi my left iPod does not charge, can you help as to what I can do to fix this? Thanks
Northerner
Hi @Claird5669
Have you tried all the fixes?
  • Make sure the case is charged up.
  • Make sure the case is clean.
  • Make sure your airpod is clean.
  • Try resetting your airpods.
If all fails and it still doesn't charge then get in touch with Apple direct.
Northerner
Hi @Claird5669
Thank you. Tried all that, I’ll contact Apple thank you
Clair Doran
