on 14-09-2022 05:42 PM
Hello
I have a blue light account and have today registered and validated my perks account.
My blc discount code does not work and also my 2 generated codes dont work ?
it keeps coming up with ''sorry, that voucher is not valid''.
The contract i am trying to get is not discounted .
Can anyone help me , i am not on EE at the moment , trying to join .
Solved! Go to Solution.
on 15-09-2022 08:11 AM
Hi @Sharon91
Did you get the code after registering on the EE Perk Portal?
If you are using a third party site this will not work you will need to register your details on the perk portal to get access to the perk discount codes.
on 14-09-2022 06:56 PM
on 14-09-2022 07:45 PM
hello i tried the none discounted zflip4 and fold and didnt work. Also tried none discounted sim only plans and still did not work
Hi @Sharon91
16-09-2022 05:16 PM - edited 16-09-2022 05:26 PM
i have it working, for some reason it does not work on Microsoft edge. i tried another browser and code works 🙂
on 16-09-2022 05:53 PM
on 11-10-2022 05:40 PM
Hello
I'm trying to use a Blue Light Card code witch I had got off a family member and I can't seem to get it to work or find out where I am meant to input the code as it tells me invalid.
Am I doing something wrong or is this because the code isn't registered to me??
Thank you
Sean
on 11-10-2022 06:46 PM
Hi @spayt1992
Is it a Blue light discount or an EE Perk discount code?
The Perk discount can only be used on plans that aren't special offers or already discounted.
Could you try on a different device or browser and let us know if it's the same? Try typing the code in manually as well and not copy & paste.
on 29-10-2022 01:27 PM
I have just change my plan and could not get my 20% discount on it could you please help me
on 29-10-2022 01:29 PM
I have register on ee perk portal
