blue light card
Cazza62
can some help I joined EE, have a blue light card and want to add the discount on that I was told I could have when I joined in the store. I have really struggled t find out how I go about this. Can you help/
Northerner
Hi @Cazza62
You can use your discount on any new or renewing plan online. Your discount can only be used on plans which do not have and discount already applied.
Northerner
Hi @Cazza62
The thing is I am struggling about how I go about getting the discount in the shop they said to contact EE. But I cannot seem to do that easily.
xxxxxx xxx
xxxxxx xxxx xxxxxxx xxxxx
xxxxxxxxxx
xxx xxx
Tel: xxx xxx xxxxx-xxxxxx
Tel: xxxxxxxx xxxxx xxxxx xxxxxx
Katie_J
Hello @Cazza62.
You will need to register for EE Perks, you will then have an account and be able to generate your discount codes there.
Katie
