Samsung TV CU8000 50"
noddy1950
Received TV this morning, tried everything to make it work, comes on but just shows plain blue screen and no sound. Who do I contact EE or Samsung
Bought it from EE but a Samsung product.
Absolutely gutted!
Katie_J
Hello @noddy1950
I am so sorry to hear this.
If you have received the product faulty please get back in touch with our customer care team as soon as possible.
Katie
Katie_J
Hello @noddy1950
Katie
Northerner
Hi @noddy1950
Make sure your firmware is up to date:
https://www.samsung.com/uk/support/model/UE55CU8000KXXU/
  • How are you connecting the TV to freesat, freeview, sky?
  • On the solar cell remote hold the button down with 123 and a cog. Then make sure you have picked the correct terrestrial link.
  • Lastly hold down the power button until the tv restarts. (Soft reset)
If the menu comes up then the tv is fine its likely how you have connected it.
Hopefully we can get this working 👊🏻
noddy1950
Thanks for your advice
Have now contacted ee and samsung. Television is faulty awaiting a call from Samsung Technical support.
Leanne_T
Thanks for letting us know @noddy1950
Hope this is sorted soon for you 🙂
