10-03-2025 05:14 PM
Right now my plan gives me the choice between
Google one , TNT sports and Xbox Game pass
None of them are particularly useful for me but I would be interested in the Apple Music sub
The Apple music isn't included in my plan, do you think EE might give me this instead of the extras available ?
Apple music is also the cheapest out of them all too
Currently using a 6 month free trial that ends in July so no rush but I'm would rather Apple music over any of the others
10-03-2025 06:14 PM
@DantheSwan Unless you have a tariff that offers this then you can not have it as an inclusive benefit.
10-03-2025 06:14 PM
24-06-2025 07:23 AM
I'm on the full works plan, very happy with it excluding one stupid thing
I cannot pick apple music as my included extra, I would need the iPhone plan for that, a plan that is identical to mine but on that you can pick apple one and on mine I cannot
There's simply no logical reason for it, that extra should be available across the board, you shouldn't need a separate plan for it
I phoned them up and they offered to cancel my contract penalty free so I could switch to that plan but
That plan is now more expensive than my one by nearly £20 now
EE solution is to cancel and pay £20 more so I can take a extra worth £12 ........ Laughable
Just combine all extras and allow people to pick whichever perk they want, of they're on android then a simple warning next to apple one will suffice
There's no reason to have a plan called "for iPhone" it's just marketing nonsense
I know this is a minor annoyance but it's the reason I most definitely won't be renewing my contract with EE
It's just so stupid
24-06-2025 09:52 AM
Hi @DantheSwan,
Thanks for visiting the EE Community
Are you in contract at the moment? It sounds like they may have been discussing doing an entirely new contract when you called, but you can request to do an in life plan change instead which should have been mentioned.
Usually doing an in life plan change will require going to a higher plan whilst in contract, however our policy when it comes to a Full works plan is that you can change from the Android version to the iPhone version or vice versa at the same cost. As long as all you are changing is the version of the plan and not any increase in data etc.
So if you do want to change to the iPhone Full works plan, to get Apple One as your benefit which includes Apple Music, if you request it as an in life plan change they should be able to sort one the same price as your current plan.
Alex
