01-03-2023 02:47 PM
Hi, wanting help to reactivate as I didn’t active quick enough and now won’t let me log in. Thanks
01-03-2023 03:10 PM
Thanks for coming here.
I have sent you a private message on here for some extra details 🙂
19-08-2023 10:41 AM
How do I reactivate ee perks account? I've have tried several times in work but it has locked me out. I'm off on maternity leave now so won't be able to access work emails from home. What can I do?
19-08-2023 11:00 AM
Hi @ESM,
Has your account been locked because your entered and incorrect password or are you seeing a 'account deactivated' error message?
19-08-2023 11:03 AM
I entered the wrong password and then believe I didn't reactivate the account quickly enough. Even when I was trying to reset password and was changing it, I couldn't gain access and it was saying account deactivated. I'm not in work now so am.unable to do anything at the moment.
19-08-2023 11:09 AM
Hi @ESM,
If your account has been deactivated, we can arrange for it to be removed from the portal so you can re-register.
In order to re-register, you'll either need access to your work email account or a photo employee ID card.
Do you have photo identification?
19-08-2023 11:13 AM
Yes I have photo ID for work. If I could re register that would be great. Do you need info from me to deactivate?
19-08-2023 11:19 AM
I've sent you a private message to take some details @ESM
09-09-2023 08:38 AM
Hi James
I’m having the same issue. It says account deactivated after I log in. Please can you help?
thanks
Imogen
09-09-2023 08:42 AM
Morning @_imogenhw
