26-09-2023 01:02 PM
Hi was wandering trying to set up tnt sports on discovery plus app. If all ready acctived on app. But when I go onto to watch something on tnt sports on it says I need to view passes what's that mean.do I click view passes will I be charged double for tnt sports
26-09-2023 03:34 PM
Hi @Markie41
Thanks for coming here.
Do you have TNT Sports showing as an active add-on in your My EE app?
Did you use the same BT ID log in details for discovery+?
Leanne 🙂
26-09-2023 04:15 PM
If got tnt sports seperate not on add on . yes I used same id as my BT login as well
26-09-2023 06:42 PM
Hi @Markie41,
Do you have TNT Sports as an inclusive add-on?
Did you previously have a BT Sport subscription with your EE account?
26-09-2023 06:47 PM
Yes I do .I tried to cancel the add on and tried re add it again will that help
26-09-2023 06:53 PM
Hi @Markie41,
Have you already cancelled the add-on?
If you have cancelled your subscription and re-added it, you should receive a text message with a link to restart the setup process.
