on 26-09-2023 09:26 PM
Hi.
I have EU roaming as an add on, am I charged daily for having it as an add on when I’m in the uk? My bill says £2.29 charged daily.
Solved! Go to Solution.
on 26-09-2023 09:43 PM
No, you are only charged the daily rate only on the days when you use any of your plan allowances abroad.
