EU data
Beckyumbers
I purchased the EU data add on and it worked for a couple days but now doesn’t work at all. I keep getting txts saying “welcome to (new country) to use data you will need to purchase an add on or pay roaming charges of ….” But in my EE app it says the add on is active. I have tried manually connecting to another network and fiddling with my settings but nothing works.
13 REPLIES 13
Alex_M
Star Contributor
Star Contributor
Hi @Beckyumbers,
Did you text ROAMING to 150 before you left the UK? If not then you will need to do it via the My EE app or website.
Just enabling the addon isn't enough.
Instructions on how to do so are available here.
Let us know how you get on!
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
Leanne_T
Hi @Beckyumbers
Thanks for coming here.
When did you purchase the add-on?
Is this still showing active in your My EE account?
Leanne 🙂
Yes it says active until the 8th July
Leanne_T
Thanks, is that the pack or the Roam like home EU add-on? @Beckyumbers
Leanne 🙂
Beckyumbers
It’s this one
My uk pack ends in 7 days
Katie_J
Hi @Beckyumbers.
Have you also purchased the roam abroad pass to ensure you can use your data abroad?
Katie
Hi I can’t see anything about a roam abroad pass on there? I purchased the 5gb of EU data to use across 30 days add-on. Why would I then have to pay to use the add on I purchased?
Katie_J
Hi @Beckyumbers.
All EE users pay as you go and pay monthly are now required to purchase a pass to use their data abroad. Even if the data you have is an additional data add-on to use this you will need a roam further pass.
Katie
