on 22-01-2023 10:49 PM
I can’t recall my password for EE perk and when I tried to reset it I get a message saying ‘we were unable to reset your password’ even though it meets the criteria. Any ideas how I can log in?
on 23-01-2023 07:54 AM
Hi @SC2504
Thanks for coming here.
Can you try using another password that you would not have used before, does this work for you?
Are you using the work email as your username?
Leanne 🙂
on 24-01-2023 06:56 AM
Yes, using work email and it won’t let me set a new password
on 24-01-2023 06:58 AM
It’s a police email and wondering if the move from .pnn has made a difference?
on 24-01-2023 07:34 AM
Hi @SC2504
To help you with your perk account, I've sent you a private message on here for some extra details.
Thanks.
