EE perks deactivated message
Niaomix
Hi I am registered with EE perks for my NHS discount. However it now says my account is deactivated due to not activating in the allocated time frame. When I try password reset it allows this to be done however when I login the same message about my account being deactivated. It won’t allow me to sign up again as says my work email is already in use. I am wanting to upgrade asap so I would like to be able to access my code for my discount again. Please can you assist? Thank you.
11 REPLIES 11
Leanne_T
Hi @Niaomix
Thanks for coming here.
I've sent you a private message on here for some details.
Hi Leanne_T
I am getting the same message as NIaomix above, would you be able to assist me as well
Joanne
Leanne_T
No problem @JoanneMarshman
Same issue here. Please could you help.
Leanne_T
Hi @MichaelB1991
I can help you with the perk account, to do this I've sent you a private message on here for some details.
Salami
Hi @Leanne_T
I have the same message, could you help me too?
Thankyou
Christopher_G
Hi @Salami
I've sent you a private message to get some information from you. Please take a look and get back to me.
JoanneMarshman
Good Morning,
How long does it take to have the account reset to enable us to re-register as I am looking to do this asap.
Joanne
Christopher_G
Hi @JoanneMarshman
It's usually done within 24 hours.
