15-01-2024 02:22 PM
I'm out of contract and an all-rounder plan seems a cost-effective way of getting TNT sports.
I understand I can change my add-on every 30 days, but how easy is this in reality?
For example, after the Champions League has finished I might want to swap to a roaming pass for the summer holidays. Does the change happen immediately, or do I have to 'switch' 29 days in advance of the final?
15-01-2024 04:27 PM
Hi there @EAB25
You can change the Inclusive Extra every 30 days in the EE app and the new Inclusive Extra should take effect within 24 hours for you.
Hope this helps 🙂
15-01-2024 04:42 PM
Hi Leanne
My TNT sports (via EE season pass) is in cancellation period and ends on Feb 4.
If I switch to the allrounder plan now do I have to choose my extra immediately or can I leave it a couple of weeks so the system doesn't freak out?
15-01-2024 05:34 PM
Hi @EAB25
You can select the Inclusive Extra and set this up once your current subscription ends 🙂
You will receive a link to activate, please keep the text and activate after Feb 4th.
