Community Activity
Re: EE website and app is unusable slow, total rubbish
EE are apparently always making updates to improve it, yet it never improves, it just gets worse. You replaced an app that worked perfectly with one that either doesn't work, as it doesn't allow you to log in, or if it actually does allow you in then...
RiaWoody by Explorer
  • 4840 Views
  • 47 replies
  • 80 Helpful
upgrading from bt to ee issues
Hi,so its got to that time where my contract has ended,and looking at ee it seems id be saving a considerable chunk compared to the extorionate amount im currently paying with be, now i have logged into BT, seen the option to look at the EE deals,pre...
Issues paying online
I've had my services suspended about a week ago because I unfortunately got behind with my bill.I was able to pay last month's bill in full, and over half of my recent bill but my services are still suspended.I keep trying to pay the remaining balanc...
Mobile data signal
I'm told by EE that indoor coverage in my area is "good".  I think this means that my signal strength should be in the range: -80 to -89 dBm.  Reality is that the very best I can achieve is -100dBm and usually the signal is in the range -110dBm to -1...
Marktewk by Investigator
  • 29 Views
  • 2 replies
  • 0 Helpful
My order
Can I have a update on my order please
Slim34 by Visitor
  • 5 Views
  • 0 replies
  • 0 Helpful
GLinet router and Ipv4
I have just purchased a GLinet x2000 router. It didn't work with either of my EE Sims I have. The Sims do work in my older and much slower TP Link router. Apparently the issue is my Sims will not get an IP address as they are iPv4 only and the GLinet...
Doddie99 by Investigator
  • 55 Views
  • 6 replies
  • 0 Helpful
EE Perks account deactivated
Himy EE perks account has been deactivated. I called 150 and was told this could not be done on the phone. Please can my EE perks account be reactivated? I did not complete the original NHS verification in time. regards adam fox
Afox93 by Explorer
  • 97 Views
  • 3 replies
  • 1 Helpful
