Britbox Benefit
MrsW
I have Britbox selected as my chosen benefit, but they are no longer accepting new sign ups due to their merge with ITVx. Apparently, you have to sign up to ITVx, but I can't find a way to do this via my EE benefit. Can anyone help?
14 REPLIES 14
Katie_J
Hi @MrsW.
Have you tried signing up for BritBox through EE HERE?
Katie
I have the same problem
Leanne_T
Hi @Stevenbaker
If you enter the number in the online set up here, this will send a PIN code to your phone. does this work for you?
Hi there no it doesn't. Is it where britbox have merged with itvx
Leanne_T
Hi @Stevenbaker
Do you have the Britbox add-on showing in your My EE app?
Hi there yes I do thanks
Leanne_T
Great thanks @Stevenbaker
Have you had any texts with a link to get set up since you have had the add-on?
Yes with a link
Leanne_T
Thanks, what happens if you set up following the link? @Stevenbaker
Have you been able to use Britbox previously?
