60min Global Roaming
Kangtastic
Hello,
Does anyone know if 150 can be covered by the 60min global roaming?
I need to call 150 but not sure if 60 minutes global roaming covers this.
@bristolian : The OP is asking about the 60 mins. Call from Anywhere add-on, not the standard roaming rates. It's a good Q! I would imagine the answer is yes. that it includes calling 150 even from outside the EU.
7 REPLIES 7
The answer depends which country you are in.
Take a read of this page - if you're within the EU, calls to C/S are free. If you're anywhere else in the world, the call will be chargeable.
What is your query - perhaps the community can help?
Hey @bristolian
I am currently in South Korea but need to talk with EE (150) but was wondering if it is worth getting the add on because the international calls in to the UK is very very expensive.
You can check the roaming costs from South Korea using the online tool here , but after 5 minutes of calling on a pay-per-minute basis, you will have covered the cost of the 60minute add-on. That's a choice only you can make, though.
What is your reason for needing to call EE? Perhaps the community can help with your query if you explain it here.
It would include calls to the 966250 number, but I was wondering if the call even needed to be made in the first place.... asking on here might save the need to call.....
Everything depends on what the query is.
@XRaySpeX @bristolian
Yes, I just needed to know if the 60minutes global roaming minutes included 150 while I was abroad but I realised that I had to call a mobile number if I was abroad ,,,,anyway I figured it out so thank you for both your help!!
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
