500 International min from outside UK
Ambos
Does the 500 International minutes add-on which allowes you to call Australia work from outside the UK too or only from UK to Australia?
If I call Australia from Austria for example is that covered in the 500min or would I be charged the normal roaming charges?
@Ambos : No, International calls are what you make from the UK to abroad. When you are abroad you are making Roaming calls. So calling Australia from Austria you will be charged roaming rates, i.e. £1.54 / min.
