wifi&Mobiledata
Joxd1
for what ever reason my iPhone 14 will not use mobile data or Wifi. it says its on and connected but won't show, I've restarted the phone 3 times, disconnected reconnect, I'm not sure if its the ESim, tbf I can't really go without my phone as I need it for work. the only thing I can do is call and FaceTime? cannot use any apps which is frustrating as I need to use whatsapp.
Any suggestions
22 REPLIES 22
Facetime is a proprietry Apple-app that uses data - be it WiFi or mobile-based.
The SIM, whether physical or electronic, controls mobile network access and has no bearing on WiFi which is just a connection between a mobile device & router.
made no sense what so ever
Leanne_T
Hi @Joxd1
What happens if you try and use any apps or Safari?
Thanks 🙂
hi
it won't  load
Leanne_T
Thanks @Joxd1
Can you try resetting the network settings, to do this go into Settings > General > Reset > Reset Network settings. This will remove any saved WiFi passwords.
Does this work for you?
Joxd1
might just have bite the bullet and do that
Jordan
Leanne_T
Let me know how you get on @Joxd1
didn't make difference
Jordan
Katie_B
Thanks for letting us know @Joxd1. ?
Are you able to test your SIM in another device to see if the issue continues?
Katie
