why all of sudden,my friends can't call my mobile
viviminmin
when they called, it says ''sorry, the number you called is not available'', i haven't blocked my friends numbers or change any setting.
Northerner
Hi @viviminmin
Are you on ee PAYG or pay monthly contract.
Are you in the UK.
Can you call them without a problem.
Hi I am with monthly contract in the UK, i can call them and send/receive msg, i am in android 9 , can't update to latest because LG abandoned mobile service. After I restart the phone, it seems works. It happened yesterday, I restarted the phone, now today, again, hope I don't need to do it again and again.
Northerner
Hi @viviminmin
Check the network status checker for issues locally.
https://coverage.ee.co.uk/coverage/ee
If it works when you restart then there maybe an issue with the device. Can you try another device.
If you can make outgoing calls, this is unlikely to be a purely coverage issue.
If you use the manual network options on your phone to force 2G/3G instead of 4G, does this make any difference to the symptoms?
