03-11-2023 06:38 PM
can I change my voicemail greeting while I am abroad? Ive been told by some no but cant see why not?
04-11-2023 08:11 PM
To change your voicemail greeting requires access to your voicemail menu. If you can do the latter, then you can do the former.
Accessing voicemail outside the UK may well require a PIN, depending on the individual network you're connected to.
04-11-2023 07:42 AM
Morning @Missmouse3
Thanks for coming here.
Have you set up a PIN to access your voicemail when abroad?
Leanne 🙂
04-11-2023 08:11 PM
