on
02-12-2024
04:44 AM
- last edited on
02-12-2024
09:49 AM
DanielPA
I have the same problem.
I'm trying to turn of voicemail by sending VM OFF to 150 but it won't send from abroad
on 02-12-2024 10:08 AM
Just dial ##002# from your phone keypad. That should clear diverts.
on 02-12-2024 09:27 PM
The solution above will work, providing the reason for "won't send from abroad" is not a lack of roaming.
If it is - then your phone won't be able to connect to any foreign networks or thus perform any network-reliant functions.
