on 15-08-2024 04:46 PM
i am at Morocco and i am not geriatric massages through at my sim
on 15-08-2024 06:03 PM
on 15-08-2024 10:14 PM
@asha15 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
