Network problems
nigeldrewitt
Hi Wise Ones,
I am in France and EE have decided to disconnect me from any network, so I can't recieve calls and I can't make calls. I have a roaming pass and a pay monthly plan. I have tried to connect manually to other networks but non appear. I'm stuck! I can't connect to EE, send texts or call them. Can any body help me out of this viscious circle? I find it incredible that EE don't have a web based chat line.
1 ACCEPTED SOLUTION
@nigeldrewitt : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Thank you for your help. Re-booting the phone seems to have solved the problem.
