24-01-2022 09:47 AM
Hi
I'm off to Costa Rica in a couple of weeks and have signed up to EE's roaming deal; £6 for 150MB of data per day. My question is how do I know day to day how much data I've used either through the EE app or on my iPhone 12? - both to utilise my allocation and/or to ensure I don't breach it.
thanks
Smeaks
24-01-2022 10:16 AM
@Smeaks you cannot go over the 150 meg per day as this is a limit per day with that add on.
If you want to track your usage each day if you go into settings/mobile data you will see a current roaming period this will count up when you are roaming and you will see what you are using each day it will not reset each day but if you scroll down to the bottom of that page you can reset all data usage.
01-02-2022 07:29 PM
thanks Chris_B,
This is helpful. It is frustrating of EE that they can sell a product but not have any good way of managing it! so you can optimise usage.
cheers
Smeaks
