on
28-04-2023
11:58 AM
- last edited on
28-04-2023
01:07 PM
DanielPA
If my mobile contract renewed in December 2021 do I have to pay roaming charges if going to Spain
Solved! Go to Solution.
on 28-04-2023 02:45 PM
You may use your usual UK allowances in the EU with up to 50 GB (contract) or 25 GB (PAYG) data per billing month if you have more. If on contract & your contract started after 07/07/2021 there'll be a £2.29 / day charge for using your UK allowances in EU or alternatively you may buy the Roam Abroad Pass for £15 / month. There are no extra roaming charges for PAYG.
If you are on contract, remember to text ROAMING to 150 before you leave UK to ensure roaming is enabled on your account.
on 28-04-2023 12:10 PM
Hello @Tenerife1249.
If your plan started after July 7th 2021 then there will be a charge for using your phone abroad.
Katie 🙂
on 28-05-2023 08:15 PM
I can’t find when my plan started
on 28-05-2023 08:17 PM
@Harold040533 : Look in your online MyEE under My Plan > Plan Details.
on 25-12-2024 05:45 PM
@Davo-UK : I wouldn't take much notice of this. It's all changed since last year. Enquire in your own thread & you shall be told.
