on 28-08-2023 01:41 PM
will I get charged for using data roaming in Glasgow
Solved! Go to Solution.
on 28-08-2023 02:13 PM
Data roaming means using mobile data whilst roaming, in the same way as voice-roaming means making calls whilst roaming.
Glasgow is in the UK and EE provides coverage there. You are not roaming when in the UK.
