calls not working
kaylao
I made a call this morning okay (8am) but now (2pm) it keeps saying that I'm 'not registered on network', can anyone help please as I need to contact my boss and other individuals.
Alex_M
Star Contributor
Star Contributor
Hi @kaylao
I'd recommend checking for problems in your area using the Network & Coverage Tool.
Put in your postcode and choose your phone model, then click 'Check Status'.
https://coverage.ee.co.uk/coverage/eehttps://coverage.ee.co.uk/coverage/ee
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
Does your phone show a mobile network connection?
The status check explained above will be a good test if you don't have coverage in a location you normally do. If your phone shows service but you have problems making calls, see if all numbers are affected or just specific ones.
